HS20 RC descreet codes
Discussion in 'Home Cinema Control & Remote Controls' started by Jack the lad, Aug 3, 2004.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    I am after remote control descreet codes specifically the HDMI code for my pronto :)
    All of the codes would be nice though :D
  2. ailean
    ailean
    You need to find someone with a programable Sony remote I'd guess. The physical HS20 remote is meant to be the same as the HS10 but the discrete codes for that don't seem to work with TVRemote pronto emulation at least. Definatly be interested if you get it working. I think the HS10 only had a couple of discrete input codes so you had to do macros to press input a couple of times after one of those, been a while since I messed about with it.
  3. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    Yeah I have used the DVI code and then set a macro to flick the INPUT one step. But thats the best I could do :)
    If you want the code I have it :)
  4. ailean
    ailean
    That's better then I could manage so yeah worth a go. ;)
    I'd probably have better luck with a real Pronto but they're just too expensive for what they do (at least the Pro NG that I want is :) ).
  5. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    This is the DVI input code :)
    0000 0067 0000 0010 0060 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 03fc
    And heres the code to move on the input select one place
    0000 0067 0060 0000 0060 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 031f 0060 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 031f 0060 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0018 0018 0030 0018
    Enjoy :)
  6. ailean
    ailean
    Nah still didn't work. :(
    Oh well back to playing input tag. :)
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    +86
    What didnt work? :)
