HS20 on a shelf?
Discussion in 'Projectors, Screens & Video Processors' started by jamiev, May 18, 2004.
  1. jamiev
    jamiev
    Jan 4, 2004
    923
    +36
    can the hs20 be mounted on a shelf rather than ceiling mount?
    does it need a lot of distance from the wall for cooling??
    :lease:
  2. monkeynuts
    monkeynuts
    May 28, 2002
    1,826
    East Devon
    +28
    Although not quite in the same league, i have an HS2 that is on a shelf at the back of my room.
    It can be put and is put close to the wall as there is enough clearance for vents (on front) and cable clearances.
    Someone with an HS20 should be able to tell you the clearances from their manual i expect and where the vents are.
    Looking at the pictures on projectorcentral.com there are a lot of slats/grills on the front.....
  3. terminal santa
    terminal santa
    The HS20 air inputs are on the bottom of the projector and it exhausts from the front, so shelf mounting is a possibility, however if you plan to have the shelf quite high up, you may need to have the pj upside-down in order to remove the need to do electronic keystone correction as the bottom (or top) of the image is in-line with the top of the lens.
    Have fun
    Terminal Santa
  4. Goragio
    Goragio
    I have my HS20 on a tall (2m) bookshelf, had to turn it upside down though.
    The only issue I have found is that the projector is relatively light and there are no feet when it's upside down; thus any knocks etc move it around.
    Will have to find a non-slip type mat or something I think.
  5. terminal santa
    terminal santa
    Hey
    My only concern with having it mounted like that on a shelf would be knocks and vibrations which i am sure arn't gonna help the lamp life - maybe a rubber mat which has some vibration deadening properties could be handy....
    just a thought
    Santa
