HS20 Lens cover
Discussion in 'Projectors, Screens & Video Processors' started by Jack the lad, Sep 18, 2004.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    You know the plastic thingy thats on when you get the unit :)
    How do you get it off? I have had a look through the manual but it doesnt say how you get it off :confused:
    Just need to get some compressed air around the lens.
    Any help appreciated :)
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,193
    +1,236
    You twist it off , about 90 degrees I seem to remember then it will just pull off. Be careful what you clean it with as its only plastic.
  3. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,641
    London
    +477
    Slide the top catch off.
    Then hold the top and bottom of the lens cover and twist it clockwise. 1/4 turn and it will release.
    Assembly is the reverse.
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Cheers fellas :thumbsup:
