HS20 and Iris function ?
Discussion in 'Projectors, Screens & Video Processors' started by Ekko Star, May 31, 2004.
  1. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,618
    London
    +468
    Can someone just clarify please....am I right in thinking having the Iris opened or closed is simply a mechanical function on the HS20 which will NOT effect or prolong Lamp life ?
    I've got mine on LOW lamp and Iris ON at the moment but I guess it's just the low lamp bit that will prolong the lamp life ? :confused:
  2. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,618
    London
    +468
    So I take it no one else knows either ?
  3. Paul D
    Paul D
    Dec 27, 2000
    2,737
    Manchester
    +534
    Only the lamp "power" will effect the bulb life.
    The Iris just "stops" down the light output, and will not effect the bulb life. :smashin:
  4. Boye
    Boye
    Very theoretically, the amount of light absorbed by the iris could cause a slightly higher temperature of the projector, and as a result shorten the life of the panels or the lamp. But other factors are much more important as to preserving lamp life: Not switching on before lamp has cooled down, sufficient airflow and so on.
