hs20 and dust!
B
bigsteve
I have just received my Sony HS20, after deliberating for several months. To my horror, as soon as the projector was powered up, I noticed a bright green blob on the bottom right hand side of the screen, indicating dust!
It is possible to focus on this, and it clearly shows a tiny hair like piece of dust. Does this indicate that the dust is on an LCD panel, or somewhere within the optics?
Is there anything I can do to remove it, as there are no dead pixels and colour uniformity is fantastic, or should I return it to the company I purchased it from?
Thanks for any advice.
Steve.
clancol
YES YES YES.
All the way back.
You don't want to go searching for dust blobs on a brand new projecter.
K
Kramer
Probably a little debris left from the manufacturing/assembly process.
Brand new PJ - yes, return it I'd say.
:smoke:
Joeki
Worth having a look in case its just on the plastic lens cover, it just clips off. I had a mark on mine but it came off easily.
65-inch LG C1 Review coming soon to AVForums
