HS20 and a room
Discussion in 'Projectors, Screens & Video Processors' started by vicbarry, Jan 12, 2004.
  1. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Just a quickie...been looking around at throw distances for the HS20....and it goes a little something like this
    I am about to purchase the sony from the US and will be celing mounting it in a 10x8 room. Smallish i know, but there is also an ensuite in there which i am using as a rack room. Looking at the throw distances on pjcentral using its projection calculator i should be able to get a dissapointing 66" diagonal image. Is this right. Anyone got a hs20 in a similar sized room...mounted 10ft back from the screen.
    I have an option of cutting a piece out of the ensuite wall and getting another 3 feet, but dont think the missus would be too happy at me smashing holes in the wall with a hammer. It was hard enough to convince her to let me have this room.
    Appreciate any ideas...
  2. Kramer
    Kramer
    Have you tried the zoom on PJ Calc?
    Indicates upto 80" diagonal from 10' throw. Also, are you including the depth of the PJ in your calculations? If your PJ is against the back wall, the lens will be approx 18" nearer the screen :eek: Worst case scenario, throw distance of just 8'6" with maximum screen width of 60".
    :smoke:
  3. sneaky
    sneaky
    Dec 14, 2003
    348
    16
    North East
    Hi Kramer,
    I have a 10' Throw. Which gives me a screen width of between 58" and 69".
    What does the Zoom actaully mean.
    Chris
  4. Joeki
    Joeki
    Jul 22, 2003
    50
    Starside
    Try and make a hole in the wall. It could be just big enough so not too ugly. And you will have no fan noise, the HS20 is noisy enough to remind you of itself when the music is off. You need those three extra feet to get the best out of this amazing machine. Some one on AVS said it was the best thing since apple pie, I am still thinking of an equivalent to this for UK. Best thing since ****!
  5. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    206
    Scotland
    +4
    Why not try and get hold of a short-throw lens?
    That might increase your screen size without any demolition?
    Either that or get a different proector!
  6. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    I have my mind set on the hs20. ive seen the short thrown lens (VPLLCW10) for $429 on bnotions. it would be a lot cheaper to mount it on a shelf behind the wall and have it the lens flush with the edge of the wall. just wondering would something like that pose a problem with ventalation for it.....
