Hs2
Discussion in 'Blu-ray & DVD Players & Recorders' started by SASMAN, Apr 10, 2003.
  1. SASMAN
    SASMAN
    Mar 17, 2003
    117
    BRISTOL
    +3
    Can you connect a PC to the HS2 for downloading to the internal hdd or to use the dvd recorder.
    Tom
    sorry if this has already been asked
  2. bobbles
    bobbles
    yes it has and yes is the answer
    however for full details you will need to do a search as I can not remember what the solution was
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
