HS2 question
Discussion in 'Blu-ray & DVD Players & Recorders' started by CARLOS, Mar 19, 2003.
  1. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    You can input an RGB signal through the scart and it outputs through S-Video, Therefore i guess it can convert, similar to an RGB to S-Video converter ?
    If so is the quality of conversion on par with a seperate converter like the JS Technolohy unit ?
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    I guess nobody knows the answer then :confused:
  3. DaveP
    DaveP
    The only way you would know was if you had such a converter and could compare the two, I doubt many people would be in that position!
    All I can say is that I use it the other way: I input s-video and output RGB. This is from my Sky+ box. I have the 20e and I cannot input RGB. The conversion is so good I cannot tell any difference (on a 36" TV) between the RGB output from the Panny and the original RGB output from the Sky+
    Hope this helps!
    DaveP
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    Ok mate thanks for the reply, It sound as though it may be as good from what you`ve said about converting the other way.
    I`ll let you know if it is, As i`ve just took delivery this afternoon of a HS2 :)
