HS2 Format DVD-RAM, can it be viewed on PC?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Adge, Sep 17, 2004.
  1. Adge
    Adge
    Hello all, long time reader, first time poster!!
    I've had a panasonic HS2 for about 18 months now and one of the problems I have is the 1:1 write speed to DVD-R, so I decided to buy a PC based DVD writer (Sony DRU-700A).
    I can read my DVD-RAM's produced on the HS2 on my PC:
    E:\>dir /s
    Volume in drive E is MEI_UDF
    Volume Serial Number is DFCA-8851
    Directory of E:\
    14/04/2004 10:40 <DIR> DVD_RTAV
    0 File(s) 0 bytes
    Directory of E:\DVD_RTAV
    14/04/2004 10:40 <DIR> .
    14/04/2004 10:40 <DIR> ..
    14/04/2004 11:06 96,142 VR_MANGR.IFO
    14/04/2004 11:06 96,142 VR_MANGR.BUP
    14/04/2004 11:06 3,917,332,480 VR_MOVIE.VRO
    3 File(s) 3,917,524,764 bytes
    Total Files Listed:
    3 Dir(s) 0 bytes free
    But can't view the video, is there a way of doing this so I can quickly copy to DVD-R on my PC and not tie up my HS2 doing a 1:1 write? Thanks in advance....
  2. Rasczak
    Rasczak
    Apr 3, 2002
    22,125
    Warwick
    +2,988
