hs10 via component
Discussion in 'Projectors, Screens & Video Processors' started by mutley, Dec 7, 2003.
  1. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    well my hs10 is conected to my pioneer 757 via component directly.
    it is also conected via s-video to pioneer 2011 than to 757.
    i can only make the component in from the HS10 work if i put "progressive" on the dvd setup (component output).
    If i put it to "interlaced" i can't get picture on hs10...
    Does component implies i can olny send progressive signal?
    I don't think so but...
    I wanted to change to interlace to try and remove the "very little" lip sync i notice on some pictures.
    Any help is welcome.
    Thanks.
    P.S. - After my first false start with the HS10 it has never done it again. Fingers crossed! 6 starts since and all OK!
  2. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    The Component connections - direct or via PJ Multi both work with Interlaced & Progressive - I've tried it - switching DVD player between I/P and the HS10 menu shows 480i/480p (NTSC) or 575i/575p (PAL)
  3. Adam M
    Adam M
    Oct 18, 2001
    724
    London
    +19
    False start?
    thats the issue with mine! have had several, eventually leading to death, which is only resolved by waiting a random amount of time for it to respond to any command via remote or on the box.
    Is this a common problem? is it sortable by a warranty claim?
