HS10 question
Discussion in 'Projectors, Screens & Video Processors' started by FazerThou, Dec 8, 2003.
  1. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
    Hi all
    Just how noisy is the HS10? The specs show it at 30db same as my HS2. As i'm considering a change this was putting me off a little as it would be sat about 2 feet directly above my head.
    Is there anyone in the Bath area that would be prepared to let me have a demo of thiers:smashin:
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Did not really find a difference between them.
    How would mount it?
    You could put it on a shelf made out of 'gert' thick MDF which may sheild any noise..........?
    Cap:smashin:
  3. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
    My HS2 is sat on a double hindged TV wall mount from argos. Iam considering a mount from LMP but i'll have to check on the lenght of my lead to see if it would reach the extra couple of metres
  4. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
    Forgot to ask, when installing should i be looking to line up the lens at the same heght as the bottom of the screen if the correct way up and vice versa?
  5. ozdvduser
    ozdvduser
    Apr 21, 2003
    170
    At The Track or Melbourne Victoria Australia
    +3
    I've got mine around 2.5 above my head and with the backend in line with the front of the chair. If it's very very silent, yes you do hear it, but it's not intrusive - and you do get used to it. Now days I really don't notice it like I did for the 1st week.
    BINGO - we have a winner :D
  6. FazerThou
    FazerThou
    Aug 23, 2003
    1,809
    Bath
    +138
    Thanks for your help
