HS10 Progressive Weirdness
Discussion in 'Plasma TVs Forum' started by Lynchpin, Jan 1, 2004.
  1. Lynchpin
    I wonder if anyone has ever had this issue and if so how or was it resolved?
    Using a prog. feed through the amp (Pioneer VSA-AX10) as it switches a component feed, on bright scenes the image can be reported as being "out of range" by the PJ. :( This extends to bright flashes on other sources as well, so I have to assume that this is an issue with the PJ, but is it a fault or a setting incorrect, even though I think I've tried everything.
    Other than that everything performs just fine and as an interlaced image from the DVD the problem goes away, but not from other sources which are obviously also interlaced.
    Just wondering if anyone else has had a similar issue.
