HS10 Problem with pics. Please look
Discussion in 'Projectors, Screens & Video Processors' started by jtorry, Oct 25, 2004.
  1. jtorry
    jtorry
    Nov 8, 2001
    522
    Right I posted a few weeks ago and have just got the projector out again to take some pics of the problem. I tried on all inputs and also using the memory stick viewer which atualy looks fine so it must some kind of problem with the inputs. It is hard to explain what is wrong so below are the pics. I think I must have caught the cables while the projector was not in use or something.
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    I've seen a similar effect when using a dvd player hooked up with component cables, but without having the dvd player set to output over component..... the colour gets messed up because the projector is expecting a composite signal, not component..... If the projector is displaying appropriately form the memory stick, then there shouldn't be a problem with the LCD panels or the firmware in the projector.
    I'd go over the signal chain again (I know you've probably done so already, but that's where the problem seems to be...), check that the source (dvd player, I assume) is set to output over comonent, check that the leads are ok (use a continuity tester) and see if you get a result. Have you tried using Svideo or composite..?
    Sean G.
  3. jtorry
    jtorry
    Nov 8, 2001
    522
    I have tried, DVI, component, Svideo and composite. The leads are fine and the dvd player is deffinately set to the right output for each lead. I have also tried a few dvd players.
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    ... well that's that so... I think you'll have to get Sony or a Service Centre to look at it - it's probably one of the circuit boards or a chip fried - I haven't had my hands ona service manual for the HS10/20, but from reading other service manuals, I seem to recall a condition which could give you that effect, requiring replacement of a chip or a small circuit board... One way or another it's got to go somewhere to get fixed. Is it under warranty?
    S.
  5. jtorry
    jtorry
    Nov 8, 2001
    522
    Unfortunately not. It is 18 months old :mad:
  6. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Oh dear............... :oops: . Commiserations are the order of the day unless someone else can come up with a solution......
    S.
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,618
    London
    +468
    Sony has closed down there main Heathrow PJ Service Centre.
    You will now have to use Pencoed Service Centre, Glamorgan Tel 01656 867400.
    I would guess you'll need to keep a handkerchief close by.... :eek:
