HS10 Overscan?
Discussion in 'Projectors, Screens & Video Processors' started by marcw, Feb 6, 2003.
  1. marcw
    marcw
    Hi all, bought a HS10 recently from Nexnix (great service BTW, highly recommended).
    Got a question. When watching movies framed at 1:85:1 anamorphic I get a small black bar at the top of the picture from the PJ. Is this an overscan problem, and how do I fix it if it is? Presumably (if it's like their TVs) I can do this in the Service Menu? How do I get to it?
    Cheers! An otherwise ecstatic HS10 owner...
  2. jorojo
    jorojo
    This is normal since your projector is 16:9 which gives an aspect ratio of 1:1.78. So if you play a film with AR 1:1.85 it will be a little bit wider which will give you very small black bars in top and bottom. This is because there is no overscan in your projector.
    John Roger
