HS10, no colour from s-video!
Discussion in 'Projectors, Screens & Video Processors' started by malcolm, Oct 7, 2003.
  1. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    Hi all,
    My HS10 arrived on friday! What a beauty :D
    I was up and running in a matter of minutes, all be it through the x-box.
    I have the bits for my HTPC arriving tomoorw :clap:
    Only problem so far is i cant get a colour s-video feed.
    I've checked both PJ and DVD are set to PAL or NTSC.
    I even get B&W if i put it through the x-box, so i dont think its the DVD player...
    Any thoughts on this?
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    which of pal or ntsc are they set to?
  3. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    i've tried all combinations.
    So... DVD set to PAL (thats the only pal option on the player.)
    Then tried the PJ on PAL, PAL-N And the other PAL option!
    Same with NTSC. No joy,... always B&W.
    I've also fried two different s-video cables and using the SONY Multi jack that comes with the PJ. All B&W.
    Am i running out of options?
  4. Mark Pitchford
    Mark Pitchford
    Mar 9, 2001
    209
    Scotland
    +4
    What cables are you using?
    I as this as I had the same problem between my freeview box and my TV when I changed the SCART lead the colour magically appeared!
  5. malcolm
    malcolm
    Jun 25, 2003
    99
    11
    Northampton
    I'm using an standard S-video cable.
    S-video out of the DVD and s-video into the PJ.
    No scarts or other connections in involved.
    i have also tried more than one s-video cable.
  6. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    try cycling through the inputs using the remote.
    I had a simliar quirk with my HS2 and found that I had to go past the first s-video option as I think that this was for the PJ multi option,
    If I remember correctly.
    Cap:smashin:
