HS10- dvi problem..
Discussion in 'Projectors, Screens & Video Processors' started by museumsteve, Jun 15, 2003.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    7,535
    3
    Nth Hampshire
    +1,008
    not a single problem with my HS10 but suddenly the dvi input seems to have died a death.
    The input says it's receiving an 800x600 signal even when nothing is plugged into the other end.
    It's been working perfectly since new with DVI but has just sort of frozen.crashed or whathever you want to call it.
    Anyone had any experience of this.? Is there a way to totally reset the machine or sort firmware etc ?
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,535
    3
    Nth Hampshire
    +1,008
    sorted...
    I unplugged the DVI cable from projector end and then turned the machine on as normal. Then switched it off and re-attached the DVI cable and it no longer shows receiving a signal when PC is not on.:)
    the bad news is I cant get the PC to output a DVI signal at all now.:( lol, but that's a different story.
