hs10 dead pixel's?
Discussion in 'Projectors, Screens & Video Processors' started by ebury, Apr 25, 2003.
  1. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    does anyone who owns the hs10 have any pixels that have died?
    and if so,how long before they died?
    Im slightly peeved because mine has a dead green pixel towards the bottom but slap bang in the middle!!Only got 20+hours on the clock:mad: :mad:
    i've also had the no start up twice!!does this seem right for£2000:mad:
    what should i do/what can i do?
    cheers hs10 owners:rolleyes:
  2. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    516
    16
    Aylesbury...where the Ducks live!!
    Well seeings as you have the start up issus as well as a dead pixel...and only 20hrs on the clock i think you have something to complaine about...
    I'd ring who ever you purchased the PJ from and tell them your not a happy bunny....
    If you bought from nexnix i know they offer very good after care
    Hope you get it sorted m8ty
  3. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    cheers respecta'
    Do you know if the front fans should be on all the time?mine turn off nearly straight away after setup!!!!
  4. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    516
    16
    I guess you have a quite hs10 then ebury...mine and other members stay on all the time...witch i think is the norm.
    Must admit i dont really notice the fans on mine in cinema black mode as i have it mounted in the coffee table at presant..
    Its a great pj and for the money i think cant be bettered..If a little noisey...and pron to faults....but hey cant have everything:rotfl:
  5. vulkan75
    vulkan75
    Hi,I have owned two hs10's.the first one i had had four dead pix all grouped together in a big bright blue dot in the middle of the screen.
    I got a exchange i have since found one dead pix in the bottom corner.but out of about three million you cant notice it.
    pixels dont die,dead pixels happen during manufacturing.As time goes by you just notice them.Some people will only offer return or exchange if you have more than a couple.
    However since you have startup and fan issues i would get an exchange.
    Dont let this put you off the hs10 it is awesome,especially with hcpc.Other projectors in this range cant match the resolution.:rotfl:
  6. Respectamonkeee
    Respectamonkeee
    Mar 24, 2002
    516
    16
    quite a few places offer to do a a dead pixel check before you buy the pj......i know i did this....
    :clap:nexnix :clap:
  7. ebury
    ebury
    Nov 5, 2002
    1,268
    41
    london
    +12
    Thats where i purchased from too!!!!!though its not there fault is it?
    I think a call to nexnix is in order during the week,just have to see what they say?
  8. Kramer
    Kramer
    'err, that's not entirely true :( Pixels can & have failed. Granted, most are defective from manufacture, but it's not unknown for a PJ to "loose" a pixel over time.
    Sony seem to have tackled this pixel issue definitevly, using a "redundant array" type feature with 2 transistors allocated for each pixel. Very few (either here or over at avs) have commented on pixel issues.
    You seem to have purchased from one of the best retailers in the UK - give them a call. I'm sure they'll "sort you out".
    Best of luck ;)
  9. Captain chaos
    Captain chaos
    But ive heard of quite a few HS10s have stuck pixels, and seem to be suffering the same LCD problems as other manufacturers...
  10. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    Yes, at Nexnix they told me that loads of HS10s have dead pixels, which is why they increased the price of their optional dead pixel check.
  11. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    641
    +16
    What is the price of the dead pixel check now? It was 20 pounds I think...
