HS10 - Bug Fix - Possitive reports
Discussion in 'Projectors, Screens & Video Processors' started by Markatlarks, Aug 5, 2003.
  1. Markatlarks
    Markatlarks
    Jan 8, 2003
    123
    Truro, Cornwall
    I have pasted below details I have found on the HS10 - Forum
    http://www.stevenhightower.net/cgi-bin/yabb/YaBB.pl?board=vpl-hs10;action=display;num=1056516727
    This Thread discusses the much talked about Bug. I have NO personal experience of the problem but because of the numerous posts on the subject - and given I am now an HS10 owner I thought that it may help others who are/were a little worried.
    Ok. Here is what Sony Support told me to do.
    Take this with a grain of salt.
    Turn off your HS-10. They told me to leave it in "Standby mode", which I took to mean off, but with the red power light on.
    Take your remote, point it at the system and hold down the following buttons.
    Light, Left Arrow, Right Arrow, and Enter.
    That's it.
    I didn't it more than a few times, and never saw any response from the system.
    Since I did it though, the amount of time it takes for the system to "power up" is back to like it was when I first purchased it.
    The technician called this a "reset" of the system. I just looked and the amount of hours put on the unit hasn't reset, I'm still around 500 hours.
    Give it a shot, and we'll see if this helps.
    Glen
    Good luck!
    PS: Have alook at the link above as the overall impression is that this really does work - honest!
