A
AngryofMayfair
I'm confused - does the supplied multi lead support RGB?
I currently have my DVD player connected to my HS10 via component out of the DVD to component in of the HS10 via the multi-input lead. I also have a Panasonic HS2 DVD recorder with RGB output via scart and I can't seem to get the HS10 to work with it so am currently connecting it via s-video...
Reading the Sony HS10 manual doesn't help much - the specs seem to indicate that the HS10 *will* accept an RGB (sync on green) input via the multi pin but I cant get it to work with the Panasonic HS2's RGB scart output.
Am I missing something obvious?
FWIW, I *hate* RGB with all it's variations and I hate scart sockets too but I am stuck with them until Panasonic bring out a dvd recorder with component outputs - like they have done in the US (I'm in Australia - where most of our equipment is PAL but with component output - not many scarts down under!)
