HS10 and progressive scan...
Discussion in 'Projectors, Screens & Video Processors' started by rjs1974, Jan 15, 2003.
  1. rjs1974
    rjs1974
    I have an HS10 and Sony DVD player, but NOT a progressive scan one. I watch mostly Region 2 DVDs via component.
    Would I see a marked improvement in picture quality if I bought a progressive scan DVD player??
    Thanks!
  2. rjs1974
    rjs1974
    I noticed on avsforums that some people are experiencing problems with prog scan with the HS10 - with the image bouncing/shaking every few seconds.
    Is anyone here using a prog scan DVD player with the HS10 with no problems?
  3. hazard
    hazard
    Apr 24, 2002
    137
    Cork
    +3
    I was using my HS10 with an Arcam DV88+ over Xmas.
    Unfortunately the Arcam had an early firmware version which suffered from the crawling dots problem, so it's gone back to be updated.
    In the time I had everything set up, though, I never experienced any problems with a bouncing or shaking picture.
  4. museumsteve
    museumsteve
    Jan 28, 2001
    8,019
    4
    Nth Hampshire
    +1,118
    I use a Pioneer 939-A in progressive and Xbox in progressive and have no probs at all.:)
