HS1 Lamp timer
Discussion in 'Projectors, Screens & Video Processors' started by JonMace, Jan 30, 2003.
  1. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Has any one managed to reset theirs?
    Replace the bulb pressed "reset" "<-" "->" "enter" to no avail several times. the message replace bulb is driving me mad any ideas?
  2. frog
    frog
    May 1, 2003
    63
    Hi, just seen your post from last november, didn't appear to be any replies.
    If it helps, I have just reset mine, make sure the projector is in standby mode. e.g. plugged in but not actually running.
