HS-50: From component to HDMI.
Discussion in 'Projectors, Screens & Video Processors' started by AlfaKhan, Mar 19, 2006.
  1. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Hi!
    I own a VPL-HS50 since early last year. Up until know I've been feeding it with a component signal from a Toshiba SD-900E DVD player and I am very pleased with the results.
    I am now considering buying the much acclaimed OPPO OPDV-971H -E player.
    Can those of you who've made this transition (Component--->DVI/HDMI, not necessarily from an Oppo) tell me if the improvement in picture quality justifies the investment.
    Thanks for any replies.
    AK
  2. Blindman
    Blindman
    Dec 12, 2004
    108
    Hi. I can't comment on your DVD player, but we demoed HDMI and component from an Arcam DV79 and a Denon 3910 when we bought our HS50, and HDMI was better on both - sharper, better colours and less noise. Whether it's worth your extra investment though, only you can tell - component was still very good. Try and get a demo.:)
  3. kishoo
    kishoo
    Feb 10, 2005
    409
    28
    Shropshire
    +23
    I too use a HS 50 ...
    Mine is feed HDMI and Component simultaniously from my DVD 5 via a JS technology component buffer.
    I can confirm that the difference between HDMI (DVI) and component is well worth an upgrade, although DVD's with edge enhancement turned on are rather nasty...
    Have a demo and see for yourself
    Kishoo
  4. kgulls
    kgulls
    Mar 6, 2004
    359
    Devon
    +23
    Yep another thumbs up for hdmi over component.Switching between the two on my Arcam dv79 shows the hdmi to provide a clearer and more defined picture on my hs50.
    Probably the only way to improve on that again would be to spend out on a decent scaler.It's all very subjective really.
  5. Lakes_Puma
    Lakes_Puma
    Jul 14, 2005
    372
    +23
    What length of HDMI cable did you use and what make of cable was it?
  6. cartman69
    cartman69
    Jul 26, 2004
    860
    28
    South Shields
    +30
    Not wanting to hijack the thread has anybody compared vga to hdmi, i currently feed my hs50 vga from a htpc, would i be better off getting a dvi to hdmi convertor and feed it this way??
  7. Blindman
    Blindman
    Dec 12, 2004
    108
    I dont know the length, but I think that it was Chord Company cable
