HS-10, does it do RGB through component
Discussion in 'Projectors, Screens & Video Processors' started by museumsteve, Jan 13, 2003.
  1. museumsteve
    museumsteve
    Jan 28, 2001
    8,019
    4
    Nth Hampshire
    +1,118
    cos the manual states it accepts RGB and then separately lists RGB via PJ Multi, so does it.? I tried from Iscan but didn't get anything..
    Also, where the hell can I get a HS30 cable from (VGA)..
  2. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    876
    46
    Maidstone, Kent
    +179
    I got all the cables I needed from a company called Mcmillan, they are a Sony Professional retailer, tel: 0208 751 3133.
    Very helpful and efficient. They didn't have the cable in stock but it arrived on the promised date.
    Give them a call, I'm sure they'll be able to help.
    cheers
    Gavin
  3. John_N
    John_N
    My HS-10 hasn't arrived yet but if the manual states it accepts RGB through the component inputs then very likely this will be RGB with sync on green.
    Basically some common RGB standards include;
    RGB + composite sync (4 wires)
    RGB + H sync + V sync (5 wires)
    RGB with sync on green (3 wires)
    I don't know enough about the iScan to comment but try getting a sync on green signal and see if that works.
  4. museumsteve
    museumsteve
    Jan 28, 2001
    8,019
    4
    Nth Hampshire
    +1,118
    another forum star.:) thanks mate. Just check ed manual again and it says sync on Green for RGB via component. This is great news for me and means I wont need to buy the HS30 cable as Quadscan can do sync on green.:)
