HP zd8290 notebook - good enough spec?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Tales 68, Oct 27, 2005.
  1. Tales 68
    Tales 68
    Feb 21, 2005
    32
    Just got a HPzd8290 notebook with the intention of running Sony Vegas Software (or similar/better? :confused:). But have just got cold feet and I'm wondering if the spec is up to it. If not I can still return it. It's a great looking notebook 17inch WXGA HD screen - Intel Pent.4 Pro.650 w/HT 3.4GHz -100GB (4200rpm) HDrive - 1024 MB DDR 553MHz SDRAM Dual Channel - ATI Mobility Radeon X600 (256MB ded.) DVD dual layer. Is this a good set up or lacking in any departments - I would greatly appreciate any comments to warm these cold feet!!!
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Take it it's got a firewire port.
    The thing that may be a stumbling block looking at that is the hard drive speed.
    You can download a trial and try it out from here
    http://www.sonymediasoftware.com/Products/showproduct.asp?PID=967&FeatureID=8239
    I think Vegas is great.
    If the full version is a bit steep & beyond your needs there is a cheaper dummed down version.
    http://www.sonymediasoftware.com/Products/ShowProduct.asp?PID=977
    Vegas in the main runs on modest systems reasonably well compared to some other NLEs
  3. Tales 68
    Tales 68
    Feb 21, 2005
    32
    Thanks for the speedy reply - yes it's got firewire - someone I was talking to today also mentioned the hard drive speed -dilemma????????
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,618
    Rainham Essex
    +2,547
    The hard drive is not too much of a problem. Just get an external firewire HDD. You should be able to get a good sized drive for under £100 preconfigured, or a separate case and drive for a bit less.
    Don't get a USB2.0 external drive as this can be too slow for video editing.
    Mark.
