HP vp6120 for £1495
Discussion in 'Projectors, Screens & Video Processors' started by pal, Jul 16, 2003.
  1. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    The latest issue of HCC has an advert from in relation to a new
    Dlp video projector.
    It has XGA resoloution,2000:1 Contrast ratio, 2000 Ansi lumens,12degree tilt ,Eco mode.
    I dont know the speed of the colour wheel.
    I've had a quote for £1495 which matches the Panny 300 I was about to buy.
    Anybody know anything for or against this projector.
    pal.
  2. PFM
    PFM
    Sep 24, 2000
    453
    Barton Upon Humber
    +17
    Yeah I saw that ad too, when I tried to look up the unit on the HP website it came under business solutions and very little was said about its HC application/use.
    I'm in the same boat, with the about to buy queries
  3. pal
    pal
    May 27, 2003
    183
    coventry
    +14
    There is more info at www.projectorpoint.co.uk. The site also takes you to a HP spec sheet and a projection distance calculator.
    The contrast ratio seems to be only 1200:1, instead of the quoted 2000:1 in the HCC advert.
  4. bunkerbuster2
    bunkerbuster2
    Plus splitting headachs and annoying rainbows have to be taken into consideration.
    Once you see one rainbow... you see them for the life of the PJ!
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
