norfbech
Established Member
Yeah, moving disks up to the top bay can be done later, you might need a reinstall of your OS though, worst case scenario!
What I'd do is: when you upgrade your memory, plug a SATA cable into the motherboard and get it routed properly so the other end is accessible from the optical bay. That way, if you decide to move a drive later, you won't have to access the motherboard again.
I'd also make sure just one drive is in the server when you do your OS install. Then add your 2Tb in afterwards.
Ok - thanks Rich...think I know where you're coming from there...without seeing the server I'm just not familiar with the internal bits and optical bays (and I'm not really techy in this respect). I presume I can just pick up a standard Sata cable when I purchase the server (there are no other cheeky parameters out to fox me? )
...and are those Kingston RAM's good to go too?
Ok...I'm diving in...wish me luck
BTW - was that free delivery voucher code knocking around this thread?
Cheers.
