HP N54L Windows 8.1 64Bit No Software Mirror Option
Discussion in 'Networking & NAS' started by nidgep, Feb 16, 2014.
  1. nidgep
    nidgep
    Feb 16, 2014
    2
    hi
    Just bought a new N54L micro server with the initial intention of it being used as a NAS.
    OS is Windows 8.1 64 bit
    Stock 250Gb Seagate (OS drive).
    2 x WD RED 3TB drives (for music/movie content).
    16 Gb RAM
    All drives are located in standard drive bays.
    After initial installation problems with the Broadcom NIC driver, got the Windows OS up and running.
    Initially disabled the on board NIC (to get the OS to install).
    The upgraded the firmware from HP to 2013.10.01 (Nov 2013)
    Then with on board NIC enabled, restarted the server, updated the driver from the Broadcom site.
    So far so good.
    Then went into Disk Management to create a mirror using the 2 x WD Red 3tb drives.
    There is no option to mirror these 2 drives, only stripe (which I dont want).
    Having read other posts in these forums, I understand that I could enable RAID in the BIOS and install the OS again, but seems that would not offer anything that should be possible from within the OS itself (but with the added negative of not being as portable).
    I have tried searching the web without any success in finding a solution to the mirroring option being missing.
    Could anyone offer a solution to this?
    All help appreciated.
  2. nidgep
    nidgep
    Feb 16, 2014
    2
    hi Guys
    Decided to go with the Storage spaces option which allows me to create a mirrored pair of disks with the option to add more disks in the future.
  3. psikey
    psikey
    Oct 5, 2005
    7,839
    3
    South Yorkshire
    +1,048
    Storage Spaces limited and not ideal (though OK for a mirrored pair). Take a look at Stablebit DrivePool if you want better.
