HP Laptop model query
Discussion in 'Desktop & Laptop Computers Forum' started by ppadaruth, Jan 10, 2008.
  1. ppadaruth
    ppadaruth
    Jan 10, 2008
    10
    Hi, first post.
    I'm looking at an HP DV9658 from PC World. However, I can't seem to find any information about it on other sites. I know that sometimes PC World and Currys get to use exclusive model numbers, and wondered if anyone could tell me if this is the case here.
    Also, i've got a voucher for £800 to use on a laptop from currys or pc world. Is this laptop a good buy, or worth putting £50 towards getting the Sony VGN-AR51J ?
    Many Thanks
    Paul
  2. M3ZZR
    M3ZZR
    Jan 10, 2008
    49
    +4
    Im a engineer for said companies mentioned..
    That model number isnt unique to them stores.. there is a spec ref on the companies support site, but I dont think technically i can post the link cause im not sure if im allowed..
    however...
    Key Features
    • Intel Core 2 Duo T7250 Processor
    • 2.0 GHz, 800MHz FSB, 2MB Cache
    • Genuine Windows Vista Home Premium
    • 2GB Memory
    • 250GB Hard Drive
    • 17" Brightview
    • HD DVD / Super Multi DVD ReWriter
    • Wifi Enabled
    • Built in TV Tuner
    CPU Intel® Core™ 2 Duo T7250 (2.00GHz)
    Chipset Intel® PM965 Express Chipset
    Memory 2GB DDR2 PC2-5300 (2x 1024 MB)
    Floppy Drive HP/Compaq Flash Memory Card Drive (5 in 1)
    CD / DVD Drive DVD±RW (Dual layer) with LightScribe
    Video / Graphics Card nVidia® GeForce 8600M GS (up to 1023MB with TurboCache)
    TV Card Yuan MPC718 MPEG2 hybrid TV tuner
    Monitor 17" WXGA+ BrightView TFT
    Sound Card 16-bit 3D SoundBlaster® compatible audio
    Modem Conexant Data Fax Modem with SmartCP
    Network Card 10 / 100 Mbps onboard LAN
    Network Card Intel® Pro 3945ABG wireless LAN
    Network Card Bluetooth™
    Firewire Card OHCI compliant IEEE 1394 host controller (onboard)
    PC Card 1 x ExpressCard/54 slot (also supports ExpressCard/34)
    Case HP® dv series 'Imprint Finish' case information
    Case HP Pavilion Webcam
    Remote HP Vista Mobile Remote Control (ExpressCard)
    Mouse HP 'Print Finish' Chassis Touchpad
    Power Supply HP® EG410AA power adapter
    Battery Compaq™ 8-cell Lithium-Ion (Li-Ion) battery
    I was working on one the other day and they seem pretty decent, but the DV range always have.
  3. ppadaruth
    ppadaruth
    Jan 10, 2008
    10
    Wow thanks for the super fast reply. Really appreciate it. Just shows you, i would never have known that laptop had an HD DVD drive going by the pcworld website.
    Cheers :)
  4. y2k
    y2k
    Jan 3, 2008
    3,300
    Banana Republic
    +291
  5. M3ZZR
    M3ZZR
    Jan 10, 2008
    49
    +4
    Here's the info on the hp, on them companies support website.
    http://support.thetechguys.com/layo...}&CatID={02af43ad-5d49-431e-8ad9-649f711bf7b4}
    the sony one should be on there as well.. if not... it may be on there in the next week or two..
    BTW, the only thing i have noticed on some of the DV9600 series was on the DV9650 (amd version of the DV9658) a batch of screens went out with 1 or 2 dead pixels.. so may be worth firing the laptop up in the shop before u take it. This wasnt a huge issue and ive only seen it on about 4 laptops, but i know some other places have had some of the same
  6. ppadaruth
    ppadaruth
    Jan 10, 2008
    10
    Thanks to both of you for those links.
    One more quick question. The laptop I had was a DV8219ea. Great for everything I needed except the keyboard was awful. Does anyone know if this has been rectified in newer models?
    cheers
  7. M3ZZR
    M3ZZR
    Jan 10, 2008
    49
    +4
    I aint come across the DV8219ea yet... but it will be a different keyboard on the 9600 series... the one i was working on the other week seemed ok to me, but just try the display model keyboard and see what that is like.
