Quantcast
HP Instant Ink Referral Code - 2 Months Free Usage
AboutQue
HP allows you to enjoy two full FREE months of HP Instant Ink usage.
All you have to do is to signup to HP instant ink and use promotional code qh2mv and freeink and you will get 2 months of free ink.
First you enter code: xxxxx to get your one month
Next you enter another code:xxxxxx to get another month on top
You can also try the code xxxxx to see if this code works for you. It works for some but does not for others so is just pot luck. But the two codes mentioned above will definitely give you 2 full months free.
Enjoy!!! :)
