HP G72 Hard drive replacement, O/S reinstallation
Discussion in 'Computer Software & Operating Systems' started by flopstocks, Mar 6, 2013.
  1. flopstocks
    flopstocks
    Jun 27, 2008
    67
    Hi my G72 laptop is showing the SMART 301 error and says the harddrive needs replacing. So I have chenged the HD and am trying to use the windows 7 recovery disks (there are 4 of them) with no luck. Spent a long time on google with no luck. If I use an old xp disk the computer finds it instantly. Any ideas?
  2. sparky10
    sparky10
    Mar 16, 2008
    1,479
    Bristol
    +256
    Hmm, I think that you need an installation disk rather than recovery disks, however there should be a serial key on the bottom of your laptop. If this is the case then you can download a full system disk from the link below and burn as an ISO file, that should do it for you. Another way of doing it is to borrow a disk from someone you know has the installation disk and use your serial number to activate it. There may be another way and other forum members may be able to advise you, but that is the only way I know, hope this helps.:smashin:
    Official Windows 7 SP1 ISO from Digital River « My Digital Life
  3. flopstocks
    flopstocks
    Jun 27, 2008
    67
  4. sparky10
    sparky10
    Mar 16, 2008
    1,479
    Bristol
    +256
