HP 15-ba046na Laptop
boam
Hi, I am looking at a laptop for my Son, and have come across this one, I can get it for circa £400 is this a good deal? And more importantly is the laptop any good?
Tech Specs are ;
Supported Operating Systems
Operating system
Windows 10 Home 64
Processor
Processor speed
2.2 GHz
Processor family AMD Quad-Core A-Series processor
Processor AMD Quad-Core A8-7410 APU (2.2 GHz, up to 2.5 GHz, 2 MB cache)
Appearance
Product color
Turbo silver
Product design Linear grooves pattern
Drives
Hard drive description
2 TB 5400 rpm SATA
Optical drive SuperMulti DVD burner
Cloud service Dropbox
Storage type HDD
Cloud service footnote number [1]
Graphic Subsystem
Graphics
AMD Radeon™ R5 Graphics
Graphics Integrated
Multimedia
Audio features
DTS Studio Sound™
Dual speakers
Webcam HP TrueVision HD Camera with integrated digital microphone
Input devices
Keyboard
Full-size island-style keyboard with integrated numeric keypad
Pointing device Touchpad with multi-touch gesture support
Connectivity and Communications
Network interface
Integrated 10/100 BASE-T Ethernet LAN
Wireless Intel® 802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Ports 1 HDMI
1 headphone/microphone combo
2 USB 2.0
1 USB 3.0
1 RJ-45
Expansion slots 1 multi-format SD media card reader
Weights
Weight
2.04 kg
Package weight 2.93 kg
Security Management
Security management
Kensington MicroSaver lock slot
Power-on password
Accepts third-party security lock devices
Trusted Platform Module (TPM) support
Software and Applications
Software included
McAfee LiveSafe™
Pre-installed software CyberLink PowerDirector
Netflix
Software - Productivity & finance 1 month trial for new Microsoft® Office 365 customers
HP apps HP Lounge
Software footnote number [2]
Dimensions
Minimum dimensions (W x D x H)
38.43 x 25.46 x 2.43 cm
Package dimensions (W x D x H) 52 x 30.5 x 6.9 cm
Display Specifications
Display size (diagonal)
39.6 cm (15.6")
Display 39.6 cm (15.6") diagonal HD SVA BrightView WLED-backlit (1366 x 768)
Memory
Memory, standard
16 GB DDR3L-1600 SDRAM (2 x 8 GB)
Standard memory note Transfer rates up to 1600 MT/s
Memory and storage 16 GB memory
2 TB HDD storage
Battery and Power
Battery type
4-cell, 41 Wh Li-ion
Power supply type 45 W AC power adapter
Battery life Up to 9 hours
Battery type note User-replaceable battery
Warranty
Warranty
1-year limited parts, labour, and pickup and return service
EndlessWaves
It's HP's bottom of the range model fitted with a model from AMD's low power 'Puma' CPU design instead of their mainstream one. The large amount of memory and storage fitted will bring the cost up a little and if they're both required then £300 would be a good deal for it.
At £400 for more typical uses it's overpriced.
Samsung S95B Update, B&W Panorama 3 & Q Acoustics Reviews, HDR PQ EOTF/Gamma Calibration Discussion
