hoya FLD and ae100 settings?
W
woody183
I have purchased the hoya FLD filter for my panny and was wondering if anyone has tinkered with the colour setting in both the service and user menu's.
If so what did you find gave best results?
I have connected mine using the pro v.
Does anyone have any idea's?
woods
K
Kramer
The AE-100 has no changeable colour controls in the "service" menu. No picture adjustments at all in there actually - just info screens.
As for the filter, calibrate after fitting with Avia.
Other's settings are meaningless. There are too many variables - screen type, sources, room environment etc...
O
olaiho
I am using a HTPC, which allows me to tinker with picture settings in the PC end. Can anyone recommend, which settings should be adjusted in order to compensate for the characteristics (pink hue etc.) of the FL-D filter?
Kramer, did you ever come around to ordering the FL-D? Is the Cinema filter on the HS10 anything like the FL-D filter?
Regards,
Olaiho
K
Kramer
No never did get the FL-D. Could have got the standard several times but really wanted the multicoated - ordered from a few places - none ever supplied.
Don't need it now - HS-10 in da house!
The usual adjustments with the HTPC + individual adjustments for RGB on the AE-100 via VGA.
