Hoya filters: PRO1 / PRO1D / S-HMC etc. HELP!!!!!
Discussion in 'Photography Forums' started by ghibbett, Sep 13, 2007.
  1. ghibbett
    ghibbett
    Dec 24, 2006
    327
    Warwickshire
    +32
    Hi All,
    Just about to purchase a Hoya CPL but the flippin' choice is driving me crazy :suicide:
    So here's the choices:
    1: Hoya 77mm PRO1 Super HMC Circular Polarizing Filter
    2: HOYA 77mm S-HMC Circular Polarizer SUPER Filter THIN
    3: HOYA 77mm PRO1 DIGITAL Circular Polarizer Filter DMC
    Any ideas of the difference and which would be best suited to being used on a EF-S 17-55 & an EF-S 10-22?
    Thanks,
  2. h4rri
    h4rri
    Mar 22, 2006
    1,988
    +159
    For the 10-22 you need the thinnest available to avoid / reduce vignetting. The differences are in the quality and clarity of the optics. A local dealer should have a little demo glass to show the difference in the quality if that helps.
  3. Yandros
    Yandros
    Oct 13, 2003
    2,714
    +528
    I use the super HMC Pro1 77mm on a Tokina 12-24mm with no problems. That one's 1mm glass, a 3mm ring, and a front thread. I think it's the most expensive of the bunch, but considering the tendency of superwides to flare, I wouldn't suggest skimping.
  4. ghibbett
    ghibbett
    Dec 24, 2006
    327
    Warwickshire
    +32
    **update**
    Have ordered the Pro1D CPL from hkdirect. Will post some piccies when it's arrived.
    Cheers,
