Hoya filter adapter to fit ae700?
Discussion in 'Projectors, Screens & Video Processors' started by CooperUK, Nov 17, 2004.
  1. CooperUK
    CooperUK
    Jun 30, 2003
    2,213
    Hampshire
    +304
    Is it possible to use the Hoya filter from my old ae100 in my new ae700 if I get an adapter to make it fit into the new PJ?
    Where, other than the obvious Jessops, might I get hold of one of these things for a reasonable price if it exists.
  2. Darwock
    Darwock
    I thought they screwed right on to the focus ring? Was the AE100 lens a smaller diameter?
  3. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,001
    Lockerbie, Scotland
    +916
    I believe the AE100 - AE500 were 55mm and as we now know the AE700 is 77mm
    KH
  4. Darwock
    Darwock
    OK, knowing that I'd guess an adaptor is impossible - if the old filter is smaller then it's just going to block the image being projected out of the larger lens, surely?
  5. OneEyedStuart
    OneEyedStuart
    Oct 12, 2003
    5,001
    Lockerbie, Scotland
    +916
    you would have to think so.
    KH
  6. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    Actually, you can get such adapters - and if the size you need isn't available, you can use a combination of two (or more). As the filter is smaller than the recommended size, you may need to watch for vignetting (darkening at the corners), especially as the zoom approaches maximum (but you can try this yourself simply by sellotaping the filter roughly in place as a test before buying any adapters)
