Hoya and component compensation on AE100
Discussion in 'Projectors, Screens & Video Processors' started by Rymdis, Jun 22, 2004.
  1. Rymdis
    Rymdis
    Is there any way to compensate the colors green and blue when using a hoya filter and a component connection, accessing only colortemp and tint on the AE100? Or MUST i have the VGA connection to do this?
    //Rymdis
  2. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    Hi and welcome to the forums........
    Using the VGA connection is the only way I know to access the RGB controls. Apart from the benefits of using a pc, I find using the hoya filter with appropriate adjustment to the colour balance makes a really big difference to the image performance.
    Sean G.
  3. Rymdis
    Rymdis
    If i in "component" mode slide the tint option to the right, the image gets
    more greenish..
    ...and if i also use cold colortemp to get more blue,
    wouldn't this be almost the same as accessing the RGB
    options in VGA mode?
  4. theritz
    theritz
    Aug 17, 2002
    2,455
    Ireland
    +27
    It's ages since I used the component-in on the AE100 so I can't really say. Effectively when you use the filter you need to increase the Green and Blue elements to restore the white balance. I doubt whether you can achieve this in the way you outline, but you can try it and see...............
    Sean G.
