Did you copy the plugin across after you installed fixpack 7? Check the file date/size in the TVSource directory. It should be 3/11/2011 time 12:28pm and size 88.0kb.
If that's correct check the EPG Collector log to see if it actually ran and if it collected any data.
Thanks nzsjb,
Yes I installed everything including the fixpack, turned off UAC and then ran EPG Collector. I used the tool to save to the source\EPG folder. I have four tuners and saved it to each one (could this be the cause of my problem)?
The last part of the log looks like this:
07:10:30:302 Station: Sky Intro (2,2012,4525) Start: 22/02/2012 06:00:00 End: 29/02/2012 12:00:00 Records: 29 Overlaps: 0 Gaps: 0
07:10:30:302 <S> Summary: Total Stations = 615 Total Gaps = 15 Total Overlaps = 1 Total Time = 00:01:20.7601131
07:10:30:312 Deleting any existing version of output file
07:10:30:312 Creating plugin output file: C:\Program Files (x86)\DVBLogic\DVBLink2\Sources\Sky_3\EPG\EPG Collector Plugin.xml
07:10:32:572 <C> Finished - created 124082 EPG entries
07:10:32:572 <C> Exiting with code = 0
07:10:32:612 Plugin notified that collection has completed with code 0
07:10:32:672 Get EPG data called for plugin monitor 2
07:10:32:672 Get EPG data buffer address=0 size=0
07:10:32:672 Replying with buffer size = 46315497
07:10:32:672 Get EPG data buffer address=1501036576 size=46315497
07:10:32:672 Passing 46315497 bytes
07:10:32:702 Data transfer complete
07:10:32:702 Plugin monitor 2 has been deleted
07:10:32:782 <C> Finished - created 124082 EPG entries
07:10:32:892 <C> Exiting with code = 0
07:10:32:912 Plugin notified that collection has completed with code 0
07:10:32:942 Get EPG data called for plugin monitor 1
07:10:32:942 Get EPG data buffer address=0 size=0
07:10:32:942 Replying with buffer size = 46315497
07:10:32:942 Get EPG data buffer address=1601372192 size=46315497
07:10:32:942 Passing 46315497 bytes
07:10:32:972 Data transfer complete
07:10:32:972 Plugin monitor 1 has been deleted
07:10:33:152 <C> Finished - created 124082 EPG entries
07:10:33:152 <C> Exiting with code = 0
07:10:33:162 Plugin notified that collection has completed with code 0
07:10:33:242 Get EPG data called for plugin monitor 3
07:10:33:242 Get EPG data buffer address=0 size=0
07:10:33:262 Replying with buffer size = 46315497
07:10:33:262 Get EPG data called for plugin monitor 3
07:10:33:272 Get EPG data buffer address=2044264480 size=46315497
07:10:33:322 Passing 46315497 bytes
07:10:33:352 Data transfer complete
07:10:33:352 Plugin monitor 3 has been deleted
07:10:34:252 <C> Finished - created 124082 EPG entries
07:10:34:252 <C> Exiting with code = 0
07:10:34:262 Plugin notified that collection has completed with code 0
07:10:34:272 Get EPG data called for plugin monitor 4
07:10:34:272 Get EPG data buffer address=0 size=0
07:10:34:272 Replying with buffer size = 46315497
And at 07:10:33 I get a Windows Application EventID1026 .NET Runtime.
Application: DVBLinkServer.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Shortly followed at 07:10:34 with Windows Application EventID1000. Application Error.
Faulting application name: DVBLinkServer.exe, version: 3.2.1.0, time stamp: 0x4d5bdb20
