Hows the Rotel RSX-1056 with stereo?
Discussion in 'AV Receivers & Amplifiers' started by Duster, Dec 8, 2004.
  1. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Hi.
    I'd just like to know how the Rotel RSX-1056 is with stereo?
    Also, can you tell me. it comes as 5.1 sound and you have to upgrade it to 7.1 sound, is this right?
  2. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    I would guess it sounds darn good. I don't have the 1056 but i've got the 1068 and 1070 power amps.
    The 1056 is only 5 channel so i'd recommend buying a new or secondhand 1070 2 channel power amp to power the front left and right, leaving the in-built 5 channels for the rest. The 1070 would make more of a difference for stereo listening then it would for movies.
    Steff
  3. hootie10
    hootie10
    I have auditioned the Rotel RSX-1056 with a number of speakers in a stereo setup (B&W, Martin Logan, Energy Veritas). This receiver performs very well in stereo to say the least. Almost as if you were using separates. I was very impressed. Right now I own it's bigger brother the RSX-1067 for a 5.1 setup in one room and a stereo setup in another room. I couldn't be happier. There is no doubt in my mind that you will like it. Good luck!!
  4. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Thanks for replys.
    It's a real shame that it's only 5.1, I need a 6.1 amp at the least, as I have a 6.1 speaker setup,
    I dont really want to buy extra power amps, as i dont have the space
