hows the footy on pwd7?
Discussion in 'Plasma TVs Forum' started by adymartin, Feb 10, 2005.
  1. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    just got some last minute jitters,anyone tell me the state of the sky sports footy on a pwd7. is it watchable, not too much blurring... pleeeeeaaase :rolleyes:
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    mate it's absolutely fine on the PW7 and that's before i get my js rgb>vga
  3. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    most definitely watchable.....................................unless your ultra sensitive..............................................you always get some motion blur.................................also depends on the cameras etc......................watching the Man Utd v Arsenal game last week and everytime it went to the high up middle camera.....................it was like there was fog on the pitch..........................close up with diff camera ok...................................Liverpool match later on..............better picture!
    but def OK, cheers,tam
  4. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    You thinking about going for this deal??
    http://www.av-sales.com/plasma/html/panasonic_th-42pw7b_plasma.html
    just trying to find some reviews of the mediabox and how go it is when connected to a Sky Digibox
    Dal
  5. Bonzodogdick
    Bonzodogdick
    Dec 1, 2004
    175
    16
    Cloud 9
    I bet last nights effort still looked p*ss poor :D
  6. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    :laugh: funny you should ask!!!
    yes i did, but i ended up leaving the media box for the following reasons.
    didn't want another piece of av equipment to find a home for and don't really need all the inputs anyway.
    I fancied the pwd7 over the pw7. ( i have no real reason for this, i'm just wierd)
    spoke to the great avsales people and instead of the js box, I was pointed in the direction of the syncblaster scart to vga cable as i only need one connection from my skybox and my dvd player will connect through the skybox aswell. I ordered a scart terminal when i ordered the set, but it looks like it's gonna be surplus to my requirments.
    bloke at avsales said that in his opinion the syncblaster cable gave pretty much the same results in quality as the js box. I'm trusting his judgement.
  7. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    fair play to you. im still undecided as to what to buy........
  8. FatBoyii
    FatBoyii
    Jan 5, 2005
    27
    4
    Watched it last night on a PW7 HD, picture was very good, infact it was the only thing that was :boring:
  9. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    Any idea whats the difference between the js tech box and synblaster cable ?
    I mean are they both the same thing but different brands?
    I understand that the js tech box need a power supply....does the syncblaster cable need a power suppy too? Lastly, how much is it?
    Sorry for all the question but this syncblaster cable is new to me...only been reading about the js tech box.
    thanks.
  10. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
  11. adymartin
    adymartin
    Jan 27, 2005
    130
    16
    syncblaster is powered
    I had a discussion with ban at av sales plasmosis. this is very loosely( my memory will not let me write exactly) what he said.
    take a look at the syncblaster cable, in my opinion it delivers just the same performance, as you only need one cable from your skybox, you don't need the js box, you can save youself some money and get rid of your scart terminal board on fleabay if you don't need it.
    i said, cheers, i'll trust your expertise mate!!
    so I am, and i'm sure everything is gonna be great!!
    i'm sure that the js offers more connection properties, but i don't need them, which is why i've gone the way i have.
    hope this helps you out.
  12. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    I asked Liam about this as I knew he had compared both...he says that in his opinion:
    "the quality difference between JS and Keene is down to the processing and cable used. Both routes have the various advantages of a decent RGB signal so both are going to come off sharp and solid. The JS adds better colour definition and less noise through using a better chipset to carry-out the sync-splicing. The further advantage comes from being able to use high quality cable to and from the converter. We're not talking leaps and bounds but the JS is better, and with it passing totally unadulterated picture information it will immediately look quite bright compared to the Keene"
  13. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    It doesn't offer more connections just a better PQ. Having said that I have used the sync blaster and it is good....but I have now ordered js rgb>vga as it was bugging me that I knew I could get even better pq than i had.
  14. plasmosis
    plasmosis
    Jan 17, 2005
    68
    london
    Thanks everyone.
    The syncblaster is powered via the scart and correct me if I am wrong but the js tech needs a power cable?
    Would everyone agree that to connect sky the syncblaster will still give a better PQ than the panny scart board?
  15. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    the sync blaster needs to be mains powered too..it says it doesn't need power for most applications...not sure what other applications it has but it gave no picture at all on pw7 without using the mains adapter.
  16. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    Not everyone on here agrees....................some have the scart and can't see the difference..................i have never compared both.......................................but took advice from the experts and got the converter.
    i'm happy with the PQ....................and i'm sure you will be as well
    cheers,tam
  17. Paulo88
    Paulo88
    Got my PW7 yesterday and wacthed the England Vs Netherlands match .... fantastic is all I can say ! :clap:
  18. tamthetim
    tamthetim
    Nov 7, 2004
    524
    Perth
    +6
    would have been if they humped you :D
    only joking............................glad you're enjoying the screen :hiya:
    cheers,tam
  19. w3dal
    w3dal
    Aug 4, 2002
    5,046
    Chelmsford, Essex
    +585
    Im going to Demo one of these Screens tomorrow just to make sure its everything i want.
    I already get a very good picture from my Sony Screen but want a bigger TV and the PW7 looks like the one to have.
    Anyone using the media box at home??
    Dal
  20. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    well i can now say that I have tried connecting sky+ to my PW7 via: 1) DMR E55, 2)Sync Blaster; and 3) JS RGB to VGA converter. Options 1 and 2 give good enough results but Option 3 is best by a long chalk, pq is visibly improved, whites are whiter, contrast is more defined and colours are more natural.
    Well done Dr John!
