How's my signal?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Garion, Dec 26, 2003.
  1. Garion
    Garion
    Jan 5, 2003
    198
    Essex
    +8
    I have a Pace Twin Freeview box with a new roof top arial.
    I am getting a signal strengh of around 80-88% across all channels
    How does this compare?
    Picture doesn't seem to freez or break up, but should I expect more? After changing from a loft arial, I did think it might be of a higher strengh then this.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    As long as the video and audio is good from all the channels on DTT then there is nothing to get concerned about and over the next few years the signal strengths will only increase so it's future proofed.
    It sounds like you were in a pretty good signal area to begin with if you were getting similar strengths from a loft aerial but there are so many variables that could influence the readings you are seeing it's not worth worrying about:)
  3. Garion
    Garion
    Jan 5, 2003
    198
    Essex
    +8
    Thank you.
  4. Fernsehman
    Fernsehman
    40 - 50% signal is usually fine. So 88% is pretty damn good.
    In fact it's so good that you *might* get problems if/when the transmitter power is increased. Be prepared to buy an attenuator.
  5. Garion
    Garion
    Jan 5, 2003
    198
    Essex
    +8
    Is signal strengh likely to increase? What is the reason behind that?
  6. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The reason why DTT has such poor coverage is due to running side by side with an analogue service which can not be compromised. As such the digital transmitters run at below optimum power to avoid interference with analogue services however when analogue is abandoned then digital power will be increased and more transmitters/frequencies will become available.
    DTT Power Increases
  7. chilpillphil
    chilpillphil
    I got my first fv box last week, its the pioneer, from my 8 year old, cheap 18 element aerial i got 92% signal.
    Hope it doesnt get anystronger :(
    my dad lives in a city, and is gonna have to get a massive xxxx off aerial which is gonna set him back £150 :(
    Mod comment - Please read the rules regarding swearing and signatures
