how would you mount these in a 6.1 setup
Discussion in 'Home Cinema Speakers' started by stuartam_81, Jul 17, 2004.
  1. stuartam_81
    stuartam_81
    Aug 17, 2003
    117
    16
    i have seen the AE b-grade offer and it sounds very good, im going to be buying a denon 3805 in a few weeks which i plan to keep for the long term, but am after some speakers that will go with it till i save up for something a bit special.
    after searching the forum a bit i found a post that mentioned the AE b-grade offers and the Aesprit 6.1 package sounds just what im looking for with 6 x AE301 and a AE308 sub.
    now i get to my question where would you mount the centre speaker ( front and rear ) ive got a pioneer 43mxe1 on order :D so would i put it above or below the screen and can they be placed on there side's ( does that effect the sound i would get ) and my last question is how would you mount the speakers ( shelves / brackets / stands ).
    all help / thoughts would be great.
