How will an alcove effect a rear ported bass?
Discussion in 'Home Cinema Speakers' started by Spiderkid, Sep 5, 2005.
  1. Spiderkid
    Spiderkid
    Sep 1, 2005
    1,174
    Liverpool
    +126
    I'm considering a few choices for some new standmount speakers for my living room (Wharfedale Diamond 8.1 @ £65, TDL KV1 @ 100 or Wharfedale Evo 8 @ £149) and the TDL's have a rear ported bass. The trouble is that the only place I can position the speakers is tucked just inside either side of a large alcove in the centre of our room. (S= Speaker)
    .....___________
    ___|S............S|____
    The front of the speaker would be well clear of the outside wall and there should be a 30cm gap between the back of the speaker and the alcove wall, but obviously the bass will be firing into a corner. Is this ok or will it confuse the sound? I'm aware that lower frequencies are 'non-directional' but I just wanted to know if I should avoid a rear ported bass in this set up?
    Thanks Tom.
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    You may find that the alcove gives an unwanted tuning effect, and many speaker manufacturers provide a foam "bung" for the port to act as a dampener in these situations.
  3. Spiderkid
    Spiderkid
    Sep 1, 2005
    1,174
    Liverpool
    +126
    Thanks for that advice Nick. Would the foam bung reduce the overall performance of the bass or just change it?
    I guess my question is, should I bother with rear ported bass in this set up if I can get equally good front ported bass?
    Cheers again
    Tom
