How to ...
Discussion in 'Home Cinema Buying & Building' started by peterkeeven, May 25, 2004.
  1. peterkeeven
    peterkeeven
    Hey,
    I've just bought a philips lx700 and an optical cable.
    My philips dvd-recorder (dvdr80) gives the signal (i can see the red light) but my receiver doesn't 'notice' it.
    The manual says to select audio, you have to press the programme button for 5 sec, then you get a menu where you can select 'digital input'. Then I have to press the programme button again and, according to the manual, I can choose between 'coaxial' or 'optical'. But I don't get the option optical!
    Can anyone help me?
  2. Big_Master
    Big_Master
    Hi man, look, you do all very good, but when you is in menu where the recyver says coaxial and you can't change this option yu can change moving the volume. there you can choose into optical or coaxial.
    sorry my english but I'm south american....
