New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Thanks for the information but it doesn't seem to be what I have? I am not sure if the sky guy would have put a connector on the end and we have lost it or it goes into the spare connector that we have?
The connector looks like this..... a small box 3.5 x 4.5 cm and 2cm thick, one one side it has a plug that fits into the BT socket and under neath the plug it has two push up connectors that look as though the telephone cable may connect into it? it it does then do both wires fit in the same side or one in each?????
On the other side it receives two telephone plugs.
Sorry I can fit electric plugs but telephone wires I no nothing about.
That's why I suggested using MySky on the Internet - and you'll get more detail there than through the receiver.
A new cable would be quite cheap so if you really do want it then I'd simply replace it.
