How to View wmv Files?
Discussion in 'General Chat' started by S.S.Dhuper, Jul 14, 2005.
  1. S.S.Dhuper
    S.S.Dhuper
    Hi there,
    My Friend in Canada sometimes sends me funny video files in Mpeg which I can see on my PC and sometimes wmv files which I can't open it says something like unable to open wrong format, can anybody tell how to view these files thanks.
  2. t-force
    t-force
    May 2, 2001
    1,850
    Southampton, UK
    +137
    WMVs should view absolutely fine in Windows Media Player.
  3. S.S.Dhuper
    S.S.Dhuper
    Hi when I click on the WMV clip, the windows media player opens then it says unable to open due to the format.
  4. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +141
    Sounds like you need a specific CODEC that isn't installed in your OS to be able to play the wmv file.
    Try a google search for K-Lite CODEC pack.
    If you don't want to be fiddling with installing video CODECS then try a piece of software called vlc.
    http://www.videolan.org/vlc/
    That usually plays anything.
    S.
