harrytherid
HI all,
The title just about says it but I have a nice 8 inch 1024x768 (VGA) native resolution monitor which I wish to use as a monitor for a reversing and rear view camera in my motorhome to replace the old low resolution setup (460 lines if my memory serves me right). It seems that the best cameras I can get are 1080p which are not compatible with the analogue monitor. I am told that I should have a 960H which, according to my research, gives a significantly lower resolution. Any ideas ? The monitor has phono and VGA sockets.
Harry
Harry
