How to utilise plasma speakers as normal amp speakers?
Discussion in 'AV Receivers & Amplifiers' started by sparkz, Nov 14, 2004.
  1. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    I'm getting a TH42PHD7 with an iScan HD scaler. The Panny will have side speakers as I like this for normal Sky viewing and only use the 5.1 for watching films.
    However, I can't work out how I can achieve this. The iScan only has a digital audio output. The Panny only has a analog audio input. And as for my amp (AVR 3803) I can't see any way of doing via this either.
    Are there any amps which have a monitor analog audio output if that makes any sense? Does anyone have any suggestions as to how I could get this result?
    I did find a audio digital to analog converter but it cost £400 :eek: I did also think of connecting the sky audio directly to the plasma but then I'd probably get lip sync problems as the picture would be routed via the scaler?
    Mark
