"How to Use SPL meter" guide
J
jonan73
Hi!
OK, finally ordered my analog SPL meter, which arrived yesterday to my place in Switzerland :)
Have you any recommandation on how to use it? (Fast/Slow)? Positionning? i read once that it was supposed to be pointed at the speaker and another site says it has to be pointed upward...
Thanks for your input!
Johann
Supra
The first thing is the weighting should be 'c', and set on slow. When I used mine I =positioned it where I sit. Then had the meter at ear level pointing towards the ceiling.
Can't remember where I got this info from now, but I did hear different views and I settled for this method myself.
I hope this helps.
MarkE19
There is a 'sticky thread' in the Subwoofer forum that gives good advise on useing an SPL meter. Click Here to have a look.
Mark.
J
jonan73
I wish there was a guide, still :(
Have a great week-end!
Johann
dinoprada2003
Supra said:
Use the 'Click Here' on MarkE19's reply, else try the following which is the same link.
SPL Meter Guide
Thats a guide for a sub via a bfd no?
Hi Jonan,
Ok all you have to do is set the SPL to slow response and C wieghting,then make sure the dial on the SPL is set to 70db and position/hold the SPL roughly where your ears are and tilt slightly upwards towards the ceiling.Now set your amps volume to 0db(this will be your refrence level) and start your speaker test tones.Now all you need to do is make sure that each channel reads 75db on the SPL by adjusting your channels +/- db settings via your amp and thats it! :thumbsup:
MarkE19
Yes, it is for setting up a sub with a BFD, but the instructions on useing the SPL are the same for the other speakers as well as a sub.
Mark.
lynx
Senior Moderator
It's generally recognised that the meter should be positioned perpindicular to the speaker.
Philips OLED807 Review, The High Price of Hi-Fi, Video Processors plus AV / HiFi News & More
