How to use PS controllers on xbox
Discussion in 'Xbox Forums' started by Bonesy, Jan 13, 2004.
  1. Bonesy
    Bonesy
    Feb 22, 2002
    1,160
    Wiltshire
    +28
    anyone bought/have experience of
    amazon thing
    buying one for a friend, just wanted recommendations...
  2. holtehero
    holtehero
    Sep 10, 2002
    2,828
    Cambridge
    +1,746
    Hello m8,
    I believe they work quite well from reading threads previously, though now the S controller for the xbox is widely available, i don't really see the need.
    Having been a PS2 user for a few years, it was strange at first to use the xbox, but i now prefer the xbox controller to the PS2 one.
    However, if they definitely want to use a PS2 pad i doubt if you will encounter problems as adaptors for USB that do the same thing for the PC have been available for a while now.
    just my 2p
  3. Azrikam
    Azrikam
    You'll also be at a disadvantage if you're playing racing games, or anything that makes use of the XBox analogue triggers.
    On the plus side, both controllers have the same number of buttons, so that shouldn't be an issue.
  4. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    I have one of these converters and have had no problems whatsoever with many varied games.Dont use it now because of s controller.
