How to use digibox if its in a cupboard?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by roriboy, Nov 21, 2004.
  1. roriboy
    roriboy
    Right, really stuck and need some expert advice...........
    Have installed an lcd on my wall and my digibox has now been installed in the cupboard which is in the room.
    Problem is that i can't change the channel with remote unless i keep the door open slightly.
    Use rf outlet with the voltage running through it to feed the splitter in the loft which feeds the bedrooms so i can't use magic eye from other outlet.
    Is there something on the market to help me out with this one???
    hope someone understands what i'm trying to ask!
    thanks
  2. Flimber
    Flimber
    Sep 22, 2002
    13,369
    Yorkshire
    +4,478
    Any ol' Remote Extender should hit the spot. E.g., Pyramid/OneForAll types.
    HTH,
    Mike.
  3. roriboy
    roriboy
    cheers for quik reply, any link to one that would do?
    And sorry to all for submitting this question twice! Thought it didn't go so clicked it again
  4. Flimber
    Flimber
    Sep 22, 2002
    13,369
    Yorkshire
    +4,478
  5. roriboy
    roriboy
    cheers for the link
    are these easy to set up and how small are they? (hard to tell in picture)
    do they need power?
    thanks
    (is there no way of me using magic eye?)
  6. roriboy
    roriboy
    anyone?
    thanks
  7. Flimber
    Flimber
    Sep 22, 2002
    13,369
    Yorkshire
    +4,478
    1. Yes
    2. Dunno
    3. Yes
    (4. Maybe)
  8. Stevvie
    Stevvie
    Oct 8, 2004
    32
    I use a magic eye conected to RF out 2 For my Sky+ that's hiden away in a hifi unit.
  9. roriboy
    roriboy
    digibox is right behind cupboard door, rf2 goes up to splitter in loft so cant use that, thinking that i could put louver vent on top of door, but is there no way of using magic eye or even extending infrared on digibox through door?
    cheers to all who have helped
  10. Stevvie
    Stevvie
    Oct 8, 2004
    32
    put the magic Eye on RF2 BEFORE it goes upstairs. I have a digibox upstairs under the multiroom agreement and it has 2 eye's on RF2. So It doesn't mater where in the cabling the eye goes.
  11. roriboy
    roriboy
    Didn't work!!!
    Ahhhrgh
    Put link into rf2 but doesn't work (light not on), but it works on two other tv's in house which come off the four way splitter in loft (which rf2 supplies)
    I don't get it, what am i not seeing????
  12. Flimber
    Flimber
    Sep 22, 2002
    13,369
    Yorkshire
    +4,478
    The 9V from the Skybox will not be effectively 'split' via your splitter, will it ?
    Mike.
  13. roriboy
    roriboy
    don't think so, think i can't do that if it feeds the splitter in loft cos it must be halfing the voltage?
    but when i plug the magic eye into rf2 and nothing else it does not light up........ strange as i thought it should work or am i missing something here?
