How to use Cambridge Audio M700
Discussion in 'Home Cinema Control & Remote Controls' started by mbrampton, Feb 5, 2005.
  1. mbrampton
    mbrampton
    I've just bought an M700 at a reduced clearance price from Richer Sounds. If anyone has figured how to use it fully, I'd be very grateful for advice on a couple of problems that don't seem to be covered by the user manual:
    1) I don't understand how the physical buttons (such as VOL-, VOL+, CH-, CH+, as opposed to the touch screen "buttons") are programmed. Currently, they don't do anything. Are the linked with particular screen "buttons" or is there some way to program them?
    2) What, if anything, can be done when a particular signal from the old device remote simply generates "Error" every time it is used? The manual says try again, but that doesn't seem much help if it keeps raising "Error". The signal is obviously received, as there is a beep and the error response.
    Best regards, Martin
